Cannot change printers
I have a problem where i cannot print on our large format printer. If i go to page setup and select the printer, it changes back to the default windows printer as soon as i close the window. Does the same thing in the actual print window too.
This just started happening. It worked fine last week. Any ideas?
1 REPLY 1
To clarify, starting today, AC11 will only let me print to the default windows printer, using the default windows settings.
I set my large format printer as the default with the settings i need, and i was able to print. This is unsatisfactory however, because the regular document printer should be the default windows printer.
