Titiriga
Change Drawing natural outline (ArchiCAD 23)
Hello,
Starting from ArcahiCAD23, the base outline of a drawing (the line type and pen its outlined with while having no specific user defined outline) is a very loose dotted line that has almost the same color as the gray background of the Layout Book environment. Its very hard to see and to work with.
How could I change the attributes of this line?
Thank you.
4 Replies 4
If you mean the frame around the drawings placed on the layouts, then I don't think you have any control of this.
It will be a dotted line if set as "Crop to Frame" and a dashed line if set as "Manually Resized Frame",
The colour will always be grey and it will not print.
You can add a printable border which you have full control over, but that may not be what you want.
Titiriga
Thank you Barry,
I sort of guessed there is no way to change that.
Hope in the next version they will do something about it, its pretty hard to work with it like this.
Thank you.
FYI:
There was another thread about this not long ago:
https://archicad-talk.graphisoft.com/viewtopic.php?f=11&t=69001
Minh from GS HQ also chimed in, so hopefully the developers are aware of this.
However, if you think this should be handled, you can make a wish for this feature, we can vote on it and if it gets enough support, we can submit it to GRAPHISOFT for consideration.
If you do make a wish, please post its link in this thread.
Titiriga
Thank you,
I didn't know about that thread, probably didn't do a good job searching for the subject.
This was my first ever post on this forum, so I'm new here. I don't really know how to make a wish and i wouldn't want that big a fuss about it either.
Thank you again
