Column is visible in View Map but invisible in Layout.
Dear friends,
I am having a peculiar issue with a specific Layout . Column is visible in View Map(See Fig -1) . but not visible in Layout Map.
I am facing this issue only with floor plan layout. Other layout (Slab layout or false slab layout is totally OK.)
I have already performed the following check.
1. column Layer's in View Map & Layout (See Fig -3).
2. Pen Set is same
3. Layer combination is same.
I would be really grateful if you can help me to fix this issue.
Here is the PLN file for my project.
https://drive.google.com/drive/folders/1OVNVhPBQ0GJgwYjBNzFDaNmiTZnFHRjv?usp=sharing
Sincewrely
Avi Shiplu
7 REPLIES 7
Have you checked your renovation filter?
HTH.
Yes, I checked the renovation. That is not the issue here.
Do you have the latest build of Archicad 23 installed - build 4006 ?
See here ...
https://archicad-talk.graphisoft.com/viewtopic.php?f=20&t=69912&p=311809&hilit=column+layout#p311809
vistasp
I opened the file in v24 and, as you said, the columns were missing in the layout.
However, removing the view from the layout and placing it again works. Don't know what is different, honestly, but it's an easy fix.
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
| AC 9-27 INT | Win11 | Ryzen 5700 | 32 GB | RTX 3050 |
vistasp
A simpler fix which also works:
Right-click on the drawing in the layout > Link Drawing To... > Select another drawing from the list.
Repeat the process, but this time choose the original (correct) drawing.
= v i s t a s p =
bT Square Peg
Even simpler.
I just opened in 23 (build 4006).
Selected drawing on layout, right click, update.
Columns now show fine.
vistasp
Barry wrote:
Even simpler.
Dang!
= v i s t a s p =
bT Square Peg
