Combining Text
Did a search - couldn't find anything. So I'm wondering, is there a way to combine separate "texts" into one? Say you've exploded a multi-line text and it turned it into several individual lines. Is there a way to combine them back into one multi-line text item? (other than "copy", "paste", "copy", "paste"... & repeat as needed)
Thanks for D help and ideas.
5 REPLIES 5
TomWaltz
I've long lamented that myself. I have never found a way.
Tom Waltz
"Good" (so to speak) to hear. I guess I can stop hoping, at least for this version. I think I remember Autocad having some lisp routines for this. Too bad something like this can't be GDLed.
Haneef Tayob
Hello
I could use a feature which combines various lines of text - You should add it to the wishlist.
It may not be at the top of everyones list, but often when we import drawings from other consultants cad packages, their text is split up and we have to manually piece them together to get a decent looking output, especially when rescaling our drawings.
Haneef Tayob
Aziz Tayob Architects
AC23 INT rel 3003, OS X 10.14.6 iMac 3.3ghz i5 dual monitor, 24GB RAM
K, good point. Wish I wouldda thought of that...
Poll is now available here: http://archicad-talk.graphisoft.com/viewtopic.php?t=8229
Frillex
Almost 20 years later, I'm wondering the same thing!
Did it ever get implemented?
Regards
Felix
AC 26, OS MONTEREY
