2024-10-14
09:38 PM
2025-07-16
12:26 PM
Molinda Prey
I have a complex profile that I modelled with the Wall tool. But somehow, it's visible only in the 3D view and not in the floor plan view. Also, the material seems to have changed. What did I do wrong?? BTW, I have no graphic override.
Operating system used: Mac Apple Silicon Windows 11 Home, AMD Ryzen 5 5600H with Radeon | 3.30 GHz | 24.0 GB RAM
Solved! Go to Solution.
2024-10-15 09:06 PM
Thanks Lingwisyer. My building materials were messed up so it didn't look right in 3D. And I changed the Show projection to Entire element in the settings dialog and it became visible in the floor plan.
2024-10-15 09:27 AM
Does your pavement slab have a Cover Fill? If so, check the draw order.
You have checked to make sure you do not have any Surface Overrides active?
2024-10-15 09:06 PM
2024-10-15 09:07 PM
Thanks, Lingwisyer. I had the building materials all messed up. And the view depth was messed up in the floor plan.
