Composite Wall SHow Colour in Section
Ode1
Hi.
I have a composite wall that shows a red dashed line through the centre. The red only shows on the floor plan. I would like it show in section (2nd pic) as well but don't know what to do. Any ideas?
It used to work in A17 but stopped by 20 if not 19...
Thanks.
Odette Salem
www.virtualhouse.com.au
AC22 AUS . Intel(R) Core(TM) i7-7800X CPU @ 3.50GHz . 32.0 GB ram . 64-bit operating system, x64-based processor
4 REPLIES 4
Are you using a different pen set in your section?
Or in your section settings,
You have the cut elements set to use 'uniform pen'.
Tim Ball
If you pick an edge of a fill you can override the line type and colour
I use this to add a reference line to say a wall that aligns with my grid lines
Tim Ball
AC26, iMac
User since V5
Exactly! I will swear I have unticked the uniform pen box and didn't get a result but I probably had something else ticked that overrode it.
Thank you as usual for your help.
Odette Salem
Thank you Tim, I will take a look at that.
Odette Salem
