Converting Old Plotter
Hi All,
I have recently purchased AC 19 and a MacBook Pro. I have an old plotter ...HP 430. I was just looking for drivers for Mac for plotter, and am not seeing any. Do you all know if these plotters can run from Mac? Also, HP 430 has serial pin connection, so I am wondering if serial pin to usb connection will work, assuming I can find driver to download?
Any info greatly appreciated as I hate to trash the plotter.
JL
David Maudlin
jronan:
Look under File > Plot Setup, there is a driver for the HP Designjet 430. I had a HP 650C (since gone to plotter heaven) and had added a Directjet card which added an ethernet connection to the plotter. I don't know about a usb-serial pin connection, but the Directjet card made a much faster connection. You could also try saving plot (.plt) files (File > Plot...), then transferring them to your old computer that is connected to the plotter.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Erwin Edel
You can also publish PLT files if you have a bulk of drawings to get through.
Same way you would publish PDF, DWG etc of your layouts (assuming you are doing that), just change 'save as' to 'plot' and choose 'destination > file' in the plot settings.
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
Thanks so much!
