Project data & BIM
Costumize issue date
Miha Nahtigal
1. Is there a way to change "Work in progress" issue date description to local language?
2. Is is possible to costumize issue date format - eg. instead of date string as "2014-07-14" to "jul. 2014"?
Thanks
BIMquants.comBETA - Quantities and Costs Estimation in Archicad - BETA testers needed.
1 REPLY 1
1. I think this is not possible, I suspect this is hard-coded into the localized version you are using.
2. this might be something that takes the system wide time format setting and uses that. Try to change the settings in your system, restart ArchiCAD and then see if that gives you the desired result.
