Creating a reflected ceiling plan step by step
Hi everyone,
I have to create my first ever reflected ceiling plan using AC13, and I cannot figure out how to do it.
I tried to find old discussions about it, but I only found discussions about how to improve one. Where do I start?
Thanks!
Enrico
13 REPLIES 13
Eduardo Rolon
For a RCP you are not looking up the concept refers to look down a see the reflection of the ceiling on the floor thus the reflected part.
Imagine that you are looking down into a mirror were you see the ceiling and you should get the idea.
You define a RCP by using layer combinations and MVOs.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
Thank you ejrolon,
Now I understand the idea šŸ™‚
Which Model View Options (MVO) can be suitable for RCP?
Eduardo Rolon
Basically the way door and windows are represented in RFC are different than in plan and it depends on local drawing conventions. You should get a copy of the RFC drawing from another project so that you can use the same drawing convention in yours.
AC29 US/INT -> AC08
another Moderator
Thank you, the problem is that I am not able to find reflected ceiling plants in internet.
Thank you again for your help.
