Guru
Curtain Wall Projection
Hi all,
I have a Curtain Wall that consists of only panels am trying to get it to show projected on the storey above. I can see it cut when the FPCP intersects it, else I just see the Reference Line when it is included in the range...
The curtain wall is set to show on All Relevant Stories with a hybrid Projected with Overhead display. Changing the Projection Mode does not appear to do anything...
I changed my FPCP settings to go down to the storey below the curtain wall, and this has only given me the curtain walls Reference Line on the storey above.
I added a frame to see if it was just something the panels were lacking, but that did not make a difference...
Ling.
Operating system used: Windows W11 24H2
2 Replies 2
CosminF
I tried to replicate your situation and I managed to get it to show projected on the above floor plan.
Home storey:
Storey above (350 above), wall height is 450 :
Settings:
FPCP:
Cosmin Furdui - architect @ Wincon
AC 27, running on Windows 11 Intel(R) Core(TM) i7-14700K CPU64, 3.40GHz, 32GB RAM, Nvidia GeForce RTX5060 32GB
Guru
Odd, it works this morning... Zzz... I even restarted yesterday...
