Sakha
Curtain wall panel
I tried to make one panel by deleting the frame between the two panels but it doesn't work and they remain separate, how do I fix it?
3 Replies 3
CosminF
You can try to:
1. Check the scheme grid - you shouldn't have a line there so that Archicad knows you don't have a separation
2. Delete both panels and hold space bar (magic wand) and fill the empty space with a one-piece panel.
Cosmin Furdui - architect @ Wincon
AC 27, running on Windows 11 Intel(R) Core(TM) i7-14700K CPU64, 3.40GHz, 32GB RAM, Nvidia GeForce RTX5060 32GB
Sakha
how to add one piece panel to the empty space?
CosminF
Delete the frame between the two panels and they should join as one.
