Curved Roof Segment Contours
Lingwisyer
Guru
Hi all,
Is there a way to hide the segment contours of a curved roof in plan? This is primarily an issue when you have a circular roof that you want to show on the floor below as the apex then becomes an extremely dense spot of lines coalescing?
Ling.
Podolsky
Ace
Use shell instead. Shell is not showing segments when it has curved surface.
Lingwisyer
Guru
No edge control, distorted textures / hatches, requires redrawing if size or pitch are modified...
