Lingwisyer
Guru
Curved Roof Segment Contours
Hi all,
Is there a way to hide the segment contours of a curved roof in plan? This is primarily an issue when you have a circular roof that you want to show on the floor below as the apex then becomes an extremely dense spot of lines coalescing?
Ling.
2 Replies 2
Podolsky
Ace
Use shell instead. Shell is not showing segments when it has curved surface.
Lingwisyer
Guru
No edge control, distorted textures / hatches, requires redrawing if size or pitch are modified...
