2017-12-12
02:43 AM
2023-05-19
03:51 PM
Gordana Radonic
2017-12-12 03:19 AM
2017-12-12 03:38 AM
Barry wrote:This is a brand new problem for me, and I'm on Mac 4022 build. I'm not sure if is started with the build update, but it could have. Not sure of the timing.
I just tested quickly.
Shut down Archicad and re-opened file with no problems (see image).
I am on Windows system build 5002.
2017-12-12 03:59 AM
2017-12-12 06:19 AM
Barry wrote:Yes--good idea generally. Unfortunately, I am three days from submitting a permit package with the file in question, so will have to wait. Thanks.
Build 5002 preview is available here ...
http://archicad-talk.graphisoft.com/viewtopic.php?t=58211
You could try that or wait a while until the official update is released - I am sure I read somewhere it would be later this month.
Duplicate your current installed program before you update.
That way if you are not happy you can just delete the whole updated program and re-name the copy to go back to 4022 - to save having to reinstall from scratch.
2017-12-27 05:03 PM
2017-12-27 06:56 PM
dkovacs wrote:Thanks for the info, Daniel. It's odd that I've never encountered/noticed this issue in the past. I'm glad to know how to counter it so I won't have to continue fixing it each time I publish.
Hello Dave,
Unfortunately this is not a bug that will be fixed in that update, this is a limitation of current Library Parts. ... Fixing this problem is on our to-do list, but it requires completely redesigning how doors/windows work, so it won't come easy (it has been like this since day one).
Thanks for understanding,
2018-02-20 08:22 PM
2018-02-21 04:49 AM
Daniel wrote:
What you should try, is to place several other dimension lines, and link that point to some other hotspot on the same edge (the inner corner of the reveal, the outer corner, where the casing and the wall meets, etc.). If none of the hotspots on that side give the desired results,you can still use a non-linked node(the little square instead of the circle, when you input the points).
| Win11 | i9 10850K | 64GB | RX6600 | Win11 | 7800X3D | 32GB | RTX5070TI |
2021-09-15 05:11 PM - edited 2021-09-15 07:12 PM
I have noticed this glitch has started cropping up in my project. I am using Archicad 24 with the latest update.
This conversation started in 2017 and it was acknowledged that this has been an issue since the start.
Why has this not been fixed yet?! It seems this option is perhaps somewhat redundant unless it is useable.
The work around I use is to copy a text box over the custom text.
