2020-05-1312:05 PM - last edited on 2025-02-0611:38 AM by Aruzhan Ilaikova
Custom/specific cut fill in cut wood elements
2020-05-1312:05 PM
Hello!
Is there any fastest way to integrate a sign like this (cross) on all cut wood elements, then doing it manually in 2d? https://ibb.co/sKv7PrD If possible, I would like to have it on all rafters and beams. I know it is possible, to achieve it with composites, but then I lose other options that a rafter for example has. Thank you for advice!
You can use Patch to create a 2D dynamic 2D object you have to put on each your beams : https://helpcenter.graphisoft.com/user-guide/88762/
Or you are able to use a complex profile by drawing a cross into your element :
Christophe - FRANCE Formateur Archicad indépendant à NANTES, PARIS Archicad 15 to 29
