narrondesigns
Custom window tags
When we toggle custom window tags on, the default text size is 17.01 and we have to manually go into the settings to change to 6.0.   Is there a setting we are missing to set the text height at 6.0 no matter what?  Thanks!
10 Replies 10
@narrondesigns ,
If you have edited the GDL of the marker to be the default size you want, that is a great start.
However, you will need to set the default size for the marker text in the window and door tools.
The tool settings will just override the GDL settings.
Once the default tool settings are made, every object you place will have the same settings until you change them.
If you use favourites, then you will also need to edit those and set the default marker size as you want.
