The answer depends on the Label's use. What will be labeled? Are the upper and lower text derived from the Labeled element or are they independent text?
David Maudlin / Architect www.davidmaudlin.com Digital Architecture AC27 USA • iMac 27" 4.0GHz Quad-core i7 OSX11 | 24 gb ram • MacBook Pro M3 Pro | 36 gb ram OSX14
The upper and lower text must derived from the Labeled element ID as seen in its properties. I just don't know yet also how to make a custom Label in ArchiCAD.
You should make sure that any of the Labels that come with ArchiCAD will do what you want. For example in the US version the Object Indicator_NCS Label will display the ID of an element.
The only way to create a custom Label is by writing GDL, which takes some time to learn. If you want to go that route, then I recommend starting with an ArchiCAD Label that is close to what you want so you don't have to script everything, but just modify parts of the scripts.
