rob2218
DOOR-WINDOW Schedules - Custom Text 1/2 NOT working in Window Schedule
see attached image.
i>u
Edgewater, FL!
SOFTWARE VERSION:
Archicad 22, Archicad 23
Windows7 -OS, MAC Maverick OS
1 Solution
At a guess I would say that the layer your window (wall) is in has been turned off.
Go to post
4 Replies 4
rob2218
You da MAN Barry,
that did it.
Why a "locked" or "hidden" window or door wont show as editable on the schedule is beyond me but that worked.
i>u
Edgewater, FL!
SOFTWARE VERSION:
DGSketcher
Legend
If you are using a View Map version of the Schedule rather than the Project Map, you can assign a layer combo to the View Settings that has the relevant layers already unlocked.
rob2218
THANKS.....that's a good point.
i>u
Edgewater, FL!
SOFTWARE VERSION:
