a week ago
Hello everyone!
This is and odd problem which I kind of resolved but still have issues.
I have some imported objects via modelport. Everything works fine until I use Publisher.
When the PDF is released objects that were made with modelport become transparent and I can see the fill pattern of the floor. However when I change PDF to raster filetype everything goes as intended. When I print single sheet with Adobe PDF the problem is still there. I've tried to save it from colleagues PC where the Foxit PDF printer is installed. Et voila I've finally got my PDF with non-transparent fills. Eventually I deduced that the problem is within Adobe PDF printer. My admin promissed to install Foxit, however what I can't resolve is how to make Publisher release documents with another PDF printer. I have over 30 sheets and I will burry myself in routine if I print each layout one by one.
a week ago
Update:
Mac's version of Publisher works as it supposed to with default settings.
