2022-10-07 05:09 PM
I have interior elevations where I see the outline of a door that is set for demolition. I assume the outline is the contour of the wall "patch" that fills in after the door goes away. Maybe I've seen this work correctly, but I can't remember what I did to get it reading correctly.
Thanks.
Solved! Go to Solution.
2022-10-09 04:00 AM
Thanks, David and Lee.
Yes, I was just overlooking a setting. My Proposed filter overrides existing walls to hide skin separators and generally make things simpler. That gives me a good plan view, but was the reason I was seeing the door outline in the interior elevations. So I just made another Renovation filter "Proposed - Elevations" the "shows" the existing, instead of overriding as described above.
Thanks for replying.
2022-10-08 10:35 AM
If you change the renovation filter status to Proposed does that help?
2022-10-08 03:40 PM
In my settings, the door outline will not show up if New Elements are set to "Show", it does show up if New Elements are set to "Override".
2022-10-09 04:00 AM
