Robert Nichols
Demolished doors show up in interior elevations (just the outline of the wall repair)
I have interior elevations where I see the outline of a door that is set for demolition. I assume the outline is the contour of the wall "patch" that fills in after the door goes away. Maybe I've seen this work correctly, but I can't remember what I did to get it reading correctly.
Thanks.
Mac Studio, 32gb ram, ArchiCAD v26 (Apple Silicon) MacOS 13
1 Solution
Robert Nichols
Thanks, David and Lee.
Yes, I was just overlooking a setting. My Proposed filter overrides existing walls to hide skin separators and generally make things simpler. That gives me a good plan view, but was the reason I was seeing the door outline in the interior elevations. So I just made another Renovation filter "Proposed - Elevations" the "shows" the existing, instead of overriding as described above.
Thanks for replying.
Go to post
3 Replies 3
Lee Hankins
If you change the renovation filter status to Proposed does that help?
Lee Hankins
ArchiCAD 4.5 - Archicad 29
macOS Tahoe (26.0)
David Maudlin
Robert Nichols:
In my settings, the door outline will not show up if New Elements are set to "Show", it does show up if New Elements are set to "Override".
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Robert Nichols
