Detail Marker
Guillermo1
Hello, in the Marker detail , why can`t write the ID layout in the Second Line?
Operating system used: Mac Intel-based 14
2 ACCEPTED SOLUTIONS
aarkell
Looks like you have it set to "Custom". If you change it to "Referred Drawing" the layout will show.
If you would like to enable both, you may need to change your marker Type. "Detail Marker 01" allows both to be enabled at the same time.
Andrew Arkell
AC 18-27 USA 5030
HP Z6 G4 Workstation | Intel(R) Xeon(R) Gold 6226R CPU @ 2.90GHz | Windows 11
Guillermo1
Thank you for the answer, also i change the "reference Marker to", selected Drawing and there it works!
aarkell
Andrew Arkell
AC 18-27 USA 5030
Guillermo1
Setup info provided by author
