NCS Drawing Title 2 27
I have noticed that in AC27 the pre-loaded drawing titles don't work as smoothly as they did in the past. Specifically, when I use NCS Drawing Title 2 27, the Drawing Title and Scale will not stay aligned with the right side of my drawing. This was a function I appreciated in 24 & 26, previous versions I used, that allowed simple manipulation of layout tidiness.
Aligned nicely to right side of drawing extents:
Won't follow drawing extents on right side: 
It seems to work if I select the drawing title, and allow it to stay on the left side, but I cannot move it to the right.
Anyone know how? I've experimented with the other drawing titles, but not found what I'm looking for yet.
Operating system used: Mac Apple Silicon Ventura 13.6.2
AC 28amp;
2021 MacBook Pro 16" 32GB Apple M1 Max
MacOS Sonoma 14.6
Marc H
One option open to you is to edit the default drawing title object or create a new one.  I've done the former for aesthetic reasons, but I expect you may be able to address your needs in this way.
Here is an older, but helpful video of creating a new one:  https://www.youtube.com/watch?v=4fup76cQOiM .  Basically, as an object, you have many options open to you.
“The best thing about the future is that it comes one day at a time.” - Abraham Lincoln
AC28 USA on 16” 2019 MBP (2.4GHz i9 8-Core, 32GB DDR4, AMD Radeon Pro 5500M 8G GDDR5, 500GB SSD, T3s, Trackpad use) running Tahoe OS + extended w/ (2) 32" ASUS ProArt PAU32C (4K) Monitors
