Detail Workflow
Hi, I'm trying to make my workflow more productive creating lists of details as objects, but it seems that this way is not as good as I wish, objects doesn't permit easy edition. So my question is if does exist some way of create a list of details to simple insert on drawing boards. For example, I'm finishing a board about sinks and bathrooms areas, it will be very helpfull if I just can drag and drop or insert some kinds of typical details, instead copying and pasting every time from older projects.
Thanks for attention!
14 Replies 14
Christophe wrote:
zesdras wrote:
...I can't understand the code to apply the changes that I've desired...
It is not code but a simple two-dimensional drawing.
Have you tried to modify the 2D symbol of a Patch?
1-Select your Patch
2-Open it by File/Library and object/Open object
3-Modify the symbol 2D and save
4-Enjoy
It is necessary to verify that the patch is created from an unoriented point of view (without rotation of the design space)
Do you want a archicad screen movie ?
Yes, please! I'd like very much to see an archicad screen movie!
Creating objects seems to me the easiest way to improve the workflow but I'm afraid we talking about different issues...
Christophe - FRANCE
Formateur Archicad indépendant à NANTES, PARIS
Archicad 15 to 29
Christophe wrote:
Thank you very much for your time! It's a new way of doing for me, now I understand what you mean with "patch". I'll try, thanks!
Patches are very good for fixing small areas that are not displaying correctly, but I am not seeing their use in developing a detail library with full notation, including notes, dimensions, and title. You might look at Eric Bobrow's 3 part tutorial on his website. Last installment (with links to the other two) is here: https://bobrow.com/archicad-tutorials/archicad-tutorial-compiling-detail-libraries/
Richard
AC26 (since AC6.0), Win10
Bullseye! Thank you very much!
