mendezarcediego
Zones with Renovation Status set to "New" won't show on Schedules
I created some Zones and set their Renovations Status to "New" and they won't show on a simple Zone Schedule. I tried to replicate the issue on a New template and everything works fine.
AC28–3110 INT FULL/ Sonoma 14.6.1 / M2 Max 12 Core/ 64 GB / 38 Core GPU
mendezarcediego
ANSWER FOUND! It's quite simple. This issue is if your working on the "Project Map" rather than the "View Map" the Schedule will inherit any random Renovation Filter which might be active in my case one that is not showing new elements, just place that empty schedule on the View Map" and save it with the desired Renovation Filter
vistasp
Mentor
Good you figured it out. It's best to form a habit of working in the View Map instead of Project Map.
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
