We value your input!
Zones with Renovation Status set to "New" won't show on Schedules
mendezarcediego
I created some Zones and set their Renovations Status to "New" and they won't show on a simple Zone Schedule. I tried to replicate the issue on a New template and everything works fine.
AC26–5002 INT FULL/ Win 11 Pro 22621.1992 / Intel i9-13900KF 24C (8P-16E) 3.00 - 5.80 GHz / 64 GB 5600 MHz DDR5 / Nvidia RTX A4500 20GB, Dual 2560x1440.
mendezarcediego
ANSWER FOUND! It's quite simple. This issue is if your working on the "Project Map" rather than the "View Map" the Schedule will inherit any random Renovation Filter which might be active in my case one that is not showing new elements, just place that empty schedule on the View Map" and save it with the desired Renovation Filter
vistasp
Good you figured it out. It's best to form a habit of working in the View Map instead of Project Map.
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
| AC 9-27 INT | Win11 | Ryzen 5700 | 32 GB | RTX 3050 |
