Detail plans
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
ā2009-04-16
08:21 PM
ā2023-05-23
03:13 AM
Gordana Radonic
I'm in a process of construction documents of a project which I already have floor plans, elevation, sections, but I need to make detailed plans of the bathrooms, closets, kitchens, etc.
What is the best way to do this?
Thanks!
- Labels:
Elevations
Views
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2009-04-17 02:48 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2009-04-17 06:44 AM
You can then add the necessary information to this view rather than your normal floor plan. Of course you will need a note layer that is seen in the enlarge plan and not the regular floor plan.
In your layout you will need to manually adjust the placed view to just show the room in question.
AC 19 6006 & AC 20
Mac OS 10.11.5
15" Retina MacBook Pro 2.6
27" iMac Retina 5K
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2009-04-17 06:54 AM
We usually place a masking fill with a hole in it to obscure areas outside the room or area you're enlarging. There can be a bit of juggling to do with text / leaders (or labels) and display order, but it's pretty easy to select it all and "bring to front"
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2009-04-17 08:02 AM
s2art wrote:Or create 2 views of the enlarged room purely for placing on the layouts (not for working on).
One has all the layers you need but not the text layer.
The other has just the text layer and nothing else.
When placed on top of each other in the layout you have all the correct layers on again.
The beauty of this is you can crop the drawing with no text to show just the amount of room space that you need - similar to the hole in your white fill but eliminatesthe backwards and forwards juggling.
Of course you still have a view with all of the correct layers on so that you can work on the plan (you don't place this on the layouts - it's just for working on).
You just have to get used to the fact that the text/dimensions will overlap the walls while you are working on the plans but will not be so in the layouts.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2009-04-17 06:31 PM
what do you think about this?
Thanks!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2009-04-18 12:08 AM
I think one of the methods above would be a much better choice.
AC 19 6006 & AC 20
Mac OS 10.11.5
27" iMac Retina 5K
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2009-04-18 02:05 AM
Thanks!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2009-04-18 06:26 AM
Which method, or what in the methods, is unclear? Take a look at the ArchiCAD reference guide (found under the help menu) to learn more about views.
All the suggestions require a view set up for for the enlarged plan. s2art uses a fill placed in the view or in the layout to mask areas that you do not want seen on the layout. Barry's method enables the notes to be separated from the plan to a certain degree to ease working. Elsewhere in the forum the concept of using a worksheet and trace reference for annotation was also suggested and is interesting enough to bring up again. In that case you would place the view of the plan and then overlay a view of the worksheet (both on the layout).
AC 19 6006 & AC 20
Mac OS 10.11.5
27" iMac Retina 5K
