Details aren't "live"
First post to this forum, new(ish) Archicad user (longtime Revit user).
I'm trying to find out how to do a detail callout that is "live" so that when the wall section changes, the detail also changes (this is supposed to be BIM after all).
I've created a composite wall (see screenshots) and an intersecting floor. I've done nothing with the Priority Based Connections or assigning priorities to anything.
In Revit, if you create a callout of something (plan or section), all of the model elements are "live" and actually show the modeled items. It appears in the callout that I've created, everything has been changed to linework.
What am I missing?
JM
25 REPLIES 25
Professor Pickle
JaseBee wrote:
Automatic back referencing can't be achieved
This is a total deal breaker. If you can't achieve automatic back-referencing then the software simply doesn't support BIM. Doing that stuff manually is insane. It's what computers are for.
Pushing the boundaries of local time/space continuum since 1972.
Archicad 26 | iMac (Retina 5K, 27-inch, 2017) | 4.2 GHz Quad-Core Intel Core i7 | 24 GB | Radeon Pro 580 8 GB | macOS 12.6
When a thread like this is still totally relevant 4 years later (T__T) tragic
The problem arises whenever you want to have a live callout from the larger plan. Like, every time I need to document the amenities or kitchens. Especially if you want the dimensions pulled off.
Literally all I want to do is increase the scale, add some text notes and dimensions.
It absolutely needs to be a live representation of the model. I almost die when I try to nudge a sink or coathook over slightly in the detail and end up selecting a bunch of dumb lines > . <
Aaargh
Can we hope that this will be added in the next version??
I have been doing this for the last 20 years without details or worksheets.
All you need is an annotation layer for each scale.
Create a layer combination for each scale using the appropriate annotation layer as well as the main model layers (which are common for all scales).
If you need to you can create a layer combination for just the model (no annotation) and a combination for each annotation layer (scale) on its own.
Then create a plan view for each of these layer combinations.
Now you can place the model view and crop it for say individual room layouts.
Then overlay the annotation view over the top.
Repeat for each scale that you need.
I posted a detailed method for this here many years ago.
I will try to find it for you later and will post a link.
Here is the link...
https://archicad-talk.graphisoft.com/viewtopic.php?p=182148
Professor Pickle
Great set of instructions and well illustrated. This is probably the best workaround in lieu of proper live callouts available from any view (ie. plans, sections, elevations)
Erwin Edel
Slight variation to this would also be possible by pinning your annotation to a custom renovation filter and saving views with this filter. No need for extra layers or layer combinations then.
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
