Diagonal dimensions
CFS_Mike
I don't see the option to create diagonal dimensions. The geometry method only gives me linear and circumference. When I click on the linear button nothing happens. I looked around but I couldn't find any options to turn it on.
Archicad 27 on macOS Sonoma 14.6
Operating system used: Mac Intel-based Sonoma 14
I find if you click to quickly on the buttons, you will see no extra options.
But if you click and hold for just a short while, the options will pop out.
4 REPLIES 4
I don't have that option! When I click on it, it does nothing.
Thank you Barry, seems odd but it worked!
Setup info provided by author
