2018-01-26
05:46 AM
2025-02-07
11:22 AM
Aruzhan Hamar
2018-01-26 08:08 AM
zsvnc wrote:You will need to clarify that question. Are you talking about using the Level Dimension Tool?
When I measure the plan at different floor heights, it measures as if it were at the same level. The interesting thing is there's nothing on the lower floor. Including the stairs. But there's actually a difference.
2018-01-27 08:21 AM
Steve wrote:I put "level dimension" on the tiles at different heights. But it seems to be the same value. Actually, someone has to be "+ 3.00" and the other one should normally be "0.00." But the "level dimension" seems to be the same value wherever I put it.zsvnc wrote:You will need to clarify that question. Are you talking about using the Level Dimension Tool?
2018-01-27 08:30 AM
Steve wrote:zsvnc wrote:You will need to clarify that question. Are you talking about using the Level Dimension Tool?
2018-01-27 02:26 PM
2018-01-28 02:28 PM
David wrote:You understand the problem correctly but it didn't work.. I dont know why?
zsvnc:
To use the Level Dimension Tool, the Slab must be on a visible Layer, you need to select the Slab option under Gravity, and you need to place it on the Slab. In your screen shot it looks like you are trying to place it in the void over the space below.
2018-01-28 02:32 PM
"David Maudlin" wrote:
zsvnc:
2018-01-28 04:25 PM
2018-01-29 03:19 AM
2018-01-29 05:36 AM
