Different Level Problem
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2018-01-26
05:46 AM
2025-02-07
11:22 AM
Aruzhan Ilaikova
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-01-26 08:08 AM
zsvnc wrote:You will need to clarify that question. Are you talking about using the Level Dimension Tool?
When I measure the plan at different floor heights, it measures as if it were at the same level. The interesting thing is there's nothing on the lower floor. Including the stairs. But there's actually a difference.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-01-27 08:21 AM
Steve wrote:I put "level dimension" on the tiles at different heights. But it seems to be the same value. Actually, someone has to be "+ 3.00" and the other one should normally be "0.00." But the "level dimension" seems to be the same value wherever I put it.zsvnc wrote:You will need to clarify that question. Are you talking about using the Level Dimension Tool?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-01-27 08:30 AM
Steve wrote:zsvnc wrote:You will need to clarify that question. Are you talking about using the Level Dimension Tool?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-01-27 02:26 PM
To use the Level Dimension Tool, the Slab must be on a visible Layer, you need to select the Slab option under Gravity, and you need to place it on the Slab. In your screen shot it looks like you are trying to place it in the void over the space below.
www.davidmaudlin.com
Digital Architecture
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-01-28 02:28 PM
David wrote:You understand the problem correctly but it didn't work.. I dont know why?
zsvnc:
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-01-28 02:32 PM
"David Maudlin" wrote:
zsvnc:
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-01-28 04:25 PM
Link.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-01-29 03:19 AM
It will not dimension anything else (such as stair treads) or if there is a void.
In version 21 there is no need to use gravity - it is automatic.
Although gravity tool can be used if you have overlapping elements (roof & slab) - but TAB works just as well (you must have quick selection active (magnet for selecting - or use SPACBAR).
In earlier versions you do need to activate the gravity tool.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-01-29 05:36 AM
So how can we add a level dimension on stairs landing?
