Different Level Problem
When I measure the plan at different floor heights, it measures as if it were at the same level. The interesting thing is there's nothing on the lower floor. Including the stairs. But there's actually a difference.
16 Replies 16
Steve Jepson
You will need to clarify that question. Are you talking about using the Level Dimension Tool?
I put "level dimension" on the tiles at different heights. But it seems to be the same value. Actually, someone has to be "+ 3.00" and the other one should normally be "0.00." But the "level dimension" seems to be the same value wherever I put it.
David Maudlin
zsvnc:
To use the Level Dimension Tool, the Slab must be on a visible Layer, you need to select the Slab option under Gravity, and you need to place it on the Slab. In your screen shot it looks like you are trying to place it in the void over the space below.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
David wrote:
zsvnc:
David
You understand the problem correctly but it didn't work.. I dont know why?
"David Maudlin" wrote:
zsvnc:
David
Link
Level Dimensions are for plan only. You need to use the Linear Dimension set to Elevation type when working in elevations and sections.
Link.
The level dimension tool will only 'lock' to a slab, roof, mesh or shell in the plan view.
It will not dimension anything else (such as stair treads) or if there is a void.
In version 21 there is no need to use gravity - it is automatic.
Although gravity tool can be used if you have overlapping elements (roof & slab) - but TAB works just as well (you must have quick selection active (magnet for selecting - or use SPACBAR).
In earlier versions you do need to activate the gravity tool.
Thank you very much for all your help. I found to add level dimension. My rpbolem was about "Floor Plan Display > Show on Stories > Home & One Story Up & Down".
So how can we add a level dimension on stairs landing?
