Different scales same floor plan AC21
Hi again everyone,
I am trying to have varied scales on 1 floor plan, basically set up documentation like an Autocad model view.
So i am hoping to have for example 1:20 of example (staircases) then details @ 1:10 and 1:2.
The reason for this is i use the documentation to build the project and need to convert my model layout to .dwg for iPad viewing in autocad. BIMX pro just does not have the accuracy and won't measure from points, i.e. lines/polylines etc, basically its just a paper layout.
Thx
1 Reply 1
DGSketcher
Legend
You aren't using Autobad, the workflow is different and no more difficult to learn...
You should be using the View Map to create different views and using the view settings to display the required scale and other aspects.
https://helpcenter.graphisoft.com/user-guide/89416/
