It seems that ALT-clicking does not transfer this dimension core only setting.
It will remain as it is set in the default for the dimension tool so you will have to check that before placing the dimension.
However the favourites do change this setting so you could save a favourite with this off and another with this on - then make sure you use your favourites when placing a dimension.
There is no change in 19.
