leven
glass surface area in window marker
Is there a way to show the glass area of a window in the marker or label of the window? I have them in my window schedule yet I'd like them to show in the floor plans too. Thanks for your help.
Levi
(Using AC23)
4 Replies 4
Which version are you using?
Depending on the version the answer may be different.
Please fill out your signature in your Profile so this info is always available.
leven
Hi Laszlo,
using AC18 now, we'll be upgrading to AC19 in the upcoming weeks, so i'd be interested in the trick for both actually...
Thanks
Levi
(Using AC23)
In a Marker: you would have to modify the GDL Script of the Window Marker object to be able to do that.
Label: yes, you can display that info in a Label.
For ARCHICAD 18, see this series of posts:
http://archicad-talk.graphisoft.com/viewtopic.php?p=233623#233623
It talks about mapping IFC Properties to an Object parameter (in your example, it will be the Glazing Area parameter), then shows how to display that IFC Property in the Generic Label 18.
In ARCHICAD 19, you have to use the Tags and Categories Label 19 instead of the Generic Label but the steps are the same.
leven
Thanks a lot, it works like a charm.
Levi
(Using AC23)
