2006-08-09
11:59 AM
2023-05-30
03:24 PM
Rubia Torres
2006-08-10 09:28 AM
Barry wrote:If you want editable elements on a single layer, it is easier to just place the drawing on the layer you want and explode it.
Another option is to open the survey in another instance of Archicad and then transfer everything into the Archicad layer.
Grouping everything together also helps.
Then copy and place the survey into your real job file and transfer to what ever layer you want it to be in.
2006-08-10 05:20 PM
Matthew wrote:Yes. Simply changing ALL to one layer does not take into account nested layers and line types within blocks. So then you'll need to explode ALL and change properties of all and (depending on your method) purge attributes... Much more efficient to use Matthew's suggestion.Barry wrote:If you want editable elements on a single layer, it is easier to just place the drawing on the layer you want and explode it.
2006-08-11 10:53 AM
andrewzarb wrote:If you need one layer, the best way is still to open the DWG as the library part, and then explode it.
The dozens of layers that surveyors use can usually be satisfactorily whittled down or merged to a couple.
