‎2006-08-30
01:00 AM
‎2023-05-30
03:23 PM
Rubia Torres
‎2006-08-30 01:26 AM
‎2006-08-30 01:46 AM
Aussie wrote:That seems to be the case. Amazingly I don't see that in the Reference Guide or the AC Help on my computer.
Dimension preferences are stored as part of the quick view. Check the settings for the saved view
‎2006-08-30 02:06 AM
Doug wrote:That is the case but you can select more than one view and change them all at once.
So I have to set the Dimension preference foreveryview?
‎2006-08-30 02:09 AM
Aussie wrote:Thanks for the tip. Actually, I forgot to thank you for the solution in your first post. So, belatedly, thank you for the great info. Every little wrinkle worked out makes working in AC more enjoyable.Doug wrote:That is the case but you can select more than one view and change them all at once.
‎2006-08-30 02:15 AM
