2024-07-11
09:14 PM
2024-07-12
06:27 AM
Rubia Torres
I open a drwing and place dimensions. they look awful with fraction and a format that is horrible.
So I edit it so that I have no fractions and reads like this 12'-4"
I immediately save,
As I work this format changes
I have to set it up again and notice:
That I open the "Options" - Project Preferences" "Dimensions " and they have changed back to the wrong stuff.
I repeat and many time have to immediate repeat as it keeps going back ti the bad dimensions.
I repeat this daily and some time many times in a day.
How do I stop this from happening.
2024-07-18 03:47 PM
This is automated in my other software, I can drag the text into staggered locations and move them in any direction.
I have had to use this feature to some extent on every job we have had over 50 years.
2024-07-24 03:42 PM
The workflow is not correct or obvious
I Go to Project Preferences -
Dimensions
Make sure to change "Fraction to None"
Custom
Store as "M2"
Item Dimensions disappear
Do a file save
reopen and first floor is still dimension however 2nd floor is not correct so change it to m2
is OK now but open 1st floor and it is back to fractions
Gone back to options and selected Custom (M2) and looks good
Went back to 2nd Floor and selected custom "M2" and it looks good
Save the file
Select Exit and it asks "SAVE?" and I save again
and then reopen
AND THE FRACTIONS ARE BACK
THIS IS NOT ACCEPTABLE AND SOMETHING IS NOT WORKING
Exit the file and reopen
2024-07-25 03:37 AM - edited 2024-07-25 03:37 AM
Seems you have updated your dimension styles which is great.
Now each view you open stores the dimension style, so you need to make sure the view settings are using the correct dimension style.
Every time you open a 'view' all of the settings will change to what is stored in the view settings.
you can change the settings on screen, but these will not affect the saved views.
