2009-09-15
11:14 PM
2023-05-23
12:01 AM
Gordana Radonic
2009-09-16 12:30 AM
2009-09-16 12:41 AM
2009-09-16 12:46 AM
2009-09-16 01:08 AM
2009-09-16 02:07 AM
2009-09-16 05:07 AM
2009-09-16 06:24 AM
gpowless wrote:Changing the Wall Reference line via the setting physically moves the wall. In order to change the reference line to the center and yet keep the wall locked in physical space, one must use the Modify Wall submenu, Modify Reference Line dialog. However, this dialog cannot be used to modify the reference line of a complex profiled wall.
Actually, a better way is to model walls with exterior (or interior) reference line and then use the Wall Reference Line setting to change the wall reference to center line. Then dimension to the intersection nodes of the walls in order to keep the dimensions dynamic.
2009-09-16 01:01 PM
2009-09-16 09:52 PM
