Dimensions Astray
vfrontiers
Just want to check to see if this is happening to anyone else. After placing a detail onto a Layout... And later coming back to view the layout, the dimension has gone haywire and seeming run in the opposite direction.
If I open the detail, the dimension looks fine, but still in the layout it is whacked. I have to UPDATE the drawing (even though it's set to AUTO UPDATE) to get it to the correct location. An UPDATE without first opening the detail does NOT correct the issue...
Ugh...
Duane
Visual Frontiers
AC25 :|: AC26 :|: AC27
:|: Enscape3.4:|:TwinMotion
Teamwork 2 issue. Affects 13 and 14. Graphisoft is working on it.
gpowless
It occurs on floor plans occasionally as well.
Intel i7-6700@3.4GHz 16g
The hotfix just released for AC14 says it fixes various dimension anomalies. You might be in luck, Duane.
Graphisoft wrote:
This Hotfix includes fixes to:
- Dimension related problems on layouts and in drawings
