Dimensions (Simple Question)
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2019-02-07
11:09 PM
‎2023-05-30
03:10 PM
Rubia Torres
‎2019-02-07
11:09 PM
How do I apply in dimensions the m for meters? Example I am having only 20.50 but I want 20.50 m.
Thanks
Eman / Draftsman
Works at an Architects Company using ArchiCad 21
Intel(R) Core(TM) i5-6500 CPU @ 3.20GHz 3.19 GHz, 8.00 GB, 64-bit operating system, x64-based processor
Solved! Go to Solution.
Labels:
- Labels:
Dimension Tools
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2019-02-08 02:13 PM
‎2019-02-08
02:13 PM
Eman:
Select just the text part of the dimension, then open its settings dialog box. Change from Measured Value to Custom Text and input <MeasuredValue> m. If you select all the text boxes you can make this change in one step for all of them.
David
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2019-02-08
02:13 PM
Eman:
David
David
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2019-02-09 09:59 AM
‎2019-02-09
09:59 AM
Hi David,
Thanks very much.
Thanks very much.
Eman / Draftsman
