Dimensions (Simple Question)
Eman
How do I apply in dimensions the m for meters? Example I am having only 20.50 but I want 20.50 m.
Thanks
Eman / Draftsman
Works at an Architects Company using ArchiCad 21
Intel(R) Core(TM) i5-6500 CPU @ 3.20GHz 3.19 GHz, 8.00 GB, 64-bit operating system, x64-based processor
David Maudlin
Eman:
Select just the text part of the dimension, then open its settings dialog box. Change from Measured Value to Custom Text and input <MeasuredValue> m. If you select all the text boxes you can make this change in one step for all of them.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
David Maudlin
Eman:
Eman
Hi David,
Thanks very much.
Eman / Draftsman
