Dimensions randomly showing up in sections
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2022-03-07 09:53 AM
I'm having an issue with unwanted dimensions showing up in my section views. I can't select the dimension itself and delete it, but I can select the dimension text and delete them that way, but they always come back when I switch to another tab and come back to the section view.
Any help with this would be greatly appreciated!
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2022-03-07 11:40 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2022-03-07 10:56 AM
got any screenshot?
ArchiCAD 9 onwards
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Maybe those are grid dimensions.
You can turn that option off here
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2022-03-07 12:44 PM
Hi!
Yes the grids seems to be cause of the problem that I'm having, but I can't seem to find the grid tool tab on where I can turn it off. This project is on AC24.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2022-03-07 12:52 PM
Last time I encountered this iirc turning the dims off in the grid didn't remove them from the sections & elevations and it was necessary to manually delete them. Depending on the nature of the grid there may be several dimensions overlaid which need deleted one at a time e.g. you delete a dimension but it then reappears after a rebuild until you have deleted them all.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2022-03-07 01:03 PM
It's in the same location as it is in 25.
Check in the work environment if the Grid tool is turned on in the Section Tool
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2022-03-07 01:40 PM
Thank you this solved my problem!
