2021-11-16 08:08 PM - edited 2021-11-16 08:24 PM
I'm trying to let dimensions attach (stick) to grids on plan.
ie. So that when I move the grid, the dimension updates to the new value.
I'm struggling to do that and was hoping for some advice.
Solved! Go to Solution.
2021-11-16 11:42 PM
when you dimensioned the grids, did you click the Grid node & not a random point along the grid line?
clicking on the node makes the Dimension Node point circular & makes it a Linked Dimension, where if it's clicked on a random point along the Grid line makes the Dimension node square & makes it a Static Dimension.
screenshot below:
2021-11-16 11:42 PM
screenshot below:
2021-11-17 12:05 AM
It's important to remind that associative dimensions only link to the permanent hotspots of any element. When dimensioning always click on a permanent hotspot, rather that a temporary one such and intersection or mid point hotspot.
2021-11-17 03:10 PM
Thanks! Works perfectly now.
