Johann_P
Dimensions to move with grids
I'm trying to let dimensions attach (stick) to grids on plan.
ie. So that when I move the grid, the dimension updates to the new value.
I'm struggling to do that and was hoping for some advice.
ArchiCAD24 - since Nov 2020
Revit - 2005 to 2020
Windows 10 Pro
2 screens: nvidia quadro RTX 4000
1 Solution
Gerry Leonor
when you dimensioned the grids, did you click the Grid node & not a random point along the grid line?
clicking on the node makes the Dimension Node point circular & makes it a Linked Dimension, where if it's clicked on a random point along the Grid line makes the Dimension node square & makes it a Static Dimension.
screenshot below:
https://discord.gg/XGHjyvutt8
Go to post
3 Replies 3
Gerry Leonor
screenshot below:
Tormenta4
It's important to remind that associative dimensions only link to the permanent hotspots of any element. When dimensioning always click on a permanent hotspot, rather that a temporary one such and intersection or mid point hotspot.
Archicad 25, MacBook Pro M1 Max, macOS Monterrey.
Johann_P
Thanks! Works perfectly now.
Windows 10 Pro
