‎2012-05-22
09:57 PM
‎2023-05-30
03:13 PM
Rubia Torres
‎2012-05-22 10:41 PM
‎2012-05-22 10:48 PM
‎2012-05-23 04:05 AM
‎2012-05-23 09:17 AM
‎2012-05-24 05:16 PM
‎2012-05-25 02:33 PM
sinceV6 wrote:You should be able to solve this issue by using the Display Order, although the Dimension Text and Lines cannot have different Display Order settings so there may be some situations that require an additional masking element.
This is something to consider if you're trying to hide dimension lines and keep only the text, because if your white pen has thickness or width, you'll see the white representation of the dimension line over other elements (such as slabs with fills, or across wall's floor plan representation).
‎2012-05-25 07:11 PM
