Disappearing dimensions in Sections/Elevations in AC10/1188
Does anyone else have the problem of disappearing dimensions in Sections & Elevations? I put them in and then when I re-open the window, they're gone. It's not a layer issue. The layer is turned on. They're just gone. It's as if they never existed. It's totally random. Sometimes it will delete one node and leave the rest of the string. Sometimes it will delete entire strings. Is there a fix for this?
5 REPLIES 5
No fix, but a work-around: place hotspots where you wish to dimension, and associate the dimensions to these hotspots.
Dimensions disappearing is S/E typically has to do with openings (doors/windows) and objects regenerating and the associativity of the dimensions getting lost in the process.
RE: this post.
Most of the dimensions that disappear are associated to the top of walls or roof ridges.
Chazz
Yup. Most longtime users of the software have concluded that you just can't associate dimension strings to things in section that also show up in plan -- they just disappear. Dimensioning to Hotspots is a lame, non associative, anti-BIM idea but it is the least bad approach I've found.
Nattering nabob of negativism
Hotspots are the most reliable work-around you have.
You can try static dimensions as well but I would not advice for detailed construction plans
I appreciate everyone's input. It seems like that's something that Graphisoft needs to fix.
Thanks again.
