Disappearing title block
Bling Keeta
Title block in layout disappears. It's in Master layout. Anything I newly draw in Master LAyout just does not appear in layout sheet. Any ideas?
Ben Ling
B.L.LING ARCHITECT INC.
Vancouver, BC, Canada
Mac Pro 3.5 GHz 6-Core Intel Xeon E5
AC 20
5 REPLIES 5
Brett Brown
Only thing I can suggest is making sure everything is on the Archicad layer
Imac, Big Sur AC 20 NZ, AC 25 Solo UKI,
Another cause could be Work Environment > User Preference Schemes > On-Screen Options > Use uniform colour for master items on Layouts, being set for white.
Had that little gem happen here yesterday!
Also select the MASTERS folder in the layout section of the Navigator and "Update" it - right click or green update button.
I have found sometimes the masters don't update and the titleblocks in there don't show on the layouts or in the PDFs.
Updating the masters fixes that.
David Maudlin
Ben:
In addition to the above suggestions, there is a command for hiding the Master Layout on Layouts, from the Help:
You can choose to hide the on-screen display of Master elements on all Layouts by turning off View > On-Screen View Options > Master Items on Layout
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Bling Keeta
Thanks everyone,
On screen View options solved the problem.
Apparently "Master items " got unchecked by itself.
Ben Ling
AC 20
