fowebe
Door Leaf Thickness on 2D Plan
Hello! Is there a way to show the door leaf's thickness on the plan? Instead of 1/4 of a circle symbol, I'd like to see the leaf. Without having to manually adding a 2D Rectangle
Phoebe
_________________
Phoebe Lim / Architect
AC26 • Windows 11
1 Solution
Andrii Levko
You can set this in Setting Dialog of door in Detail Level assing scale 1:50 for 2D detail level or using MVO1.JPG
As option select it in MVO
Andrii
AC 8.1 - 28 INT/POL 3001
Win11
Go to post
3 Replies 3
fowebe
image_2022-07-27_125815312.pngimage_2022-07-27_125841567.pngInstead of having to manually adding a 2D Rectangle
Phoebe
_________________
AC26 • Windows 11
Andrii Levko
Andrii
Win11
Andrii Levko
For Editing thickness of leaf select Frame and Leaf and set needing thickness.2.JPG
Andrii
Win11
