2022-07-27 06:57 AM - edited 2022-07-27 07:00 AM
Hello! Is there a way to show the door leaf's thickness on the plan? Instead of 1/4 of a circle symbol, I'd like to see the leaf. Without having to manually adding a 2D Rectangle
Thank you to anyone who can answer!
Solved! Go to Solution.
2022-07-27 07:09 AM - edited 2022-07-27 07:37 AM
You can set this in Setting Dialog of door in Detail Level assing scale 1:50 for 2D detail level or using MVO
As option select it in MVO
2022-07-27 06:59 AM
Instead of having to manually adding a 2D Rectangle
2022-07-27 07:30 AM
For Editing thickness of leaf select Frame and Leaf and set needing thickness.
